My 2019 Ram 1500 Classic has a different shift time and slip / torque management between Tow Mode and Normal driving. I was able to tune 95% of the transmission but I can't figure why the shift timing & Torque Management is different when I use the Tow mode. Basicaly, I would like theses maps exactly the same between Tow Mode and Normal driving. The Tow Mode is perfect !
Does the tow mode uses "Max" table values ? (Shift Timing Up shift & Trq Management) ?
Yes I already adjusted all 5 tow shift pattern maps, I did search a lot on the forum with no luck.
