Results 1 to 17 of 17
Thread: Thoughts on speed density only tune?
    I'm primarily a Ford tuner, but I recently bought a WS6 02 Trans Am that has been tuned full time speed density (there's no MAF either). I am curious what people's thoughts are on this method for GM tuning. The car doesn't feel like it's running as well as it could. Thanks!
    13,565
    Nothing wrong with speed density only, tons of people do it and it's basically the best way to go with boost too.
    Arizona
    452
    Quote Originally Posted by Power Surge View Post
    mothing wrong with SD, but, if you think something is wrong, need to scan it to see what is right or wrong.
    Or just set up a dyno appointment
    Dec 2019
    MS
    567
    I run SD on all the Turbo trucks and cars.
    My turbo truck has been SD for 19 years now.
    Get a wideband on the car and see what its doing.
    2,742
    Aren't all dodges Speed density?
    Speed density is great. People will blame bad tuning on speed density. It's harder for the inexperienced to tune and that's likely where that comes from.
    The foundation of any great tune is properly tuned speed density first. MAF comes later.
    Tuner at PCMofnc.com
    Feb 2017
    miami
    1,799
    I tuned hundreds of maf cars. I do not like the maf sensor if I can avoid it. The maf is very easy to tune in theory- saves tuners alot of time, tune an engine in a couple hours usually on the maf. That is why I think tuners like maf sensor tuning, they get the job done quickly in and out. But the maf is a fickle bitch and blurry to tune. Its like a average tune even on the best of days. For 4 and 6 cylinder engines the discrepancy is fine because those engines sip fuel. But if you really want to max out economy and plug cleanliness and reduce carbon deposits and keep the engine clean in a V8 application - I recommend learning to fully tune the MAP situation. Not just the VE Table mind you but the entire repertoire of tools laid out that interact with airmass calculations and VE interference to such a degree that the engine no longer requires a closed loop and runs with superior response, power, economy, cleanliness while in open loop on the MAP.
    Ok... here is the file dump out of my 02 WS6. If anyone feels like taking a look at it and seeing if there's anything that doesn't look right before I start tinkering with it, that would be appreciated.
    WS6dump.hpt
    Arizona
    452
    Ok... here is the
    VE is a bit choppy
    timing is interesting both HO and LO
    why leaning out the PE in the higher revs?
    Mar 2022
    Indiana
    2,951
    What chimp tuned this? You'd be better off starting with a factory tune and then converting it to SD.
    2,742
    I'd start with a stock file..
    They barely touched the VE.. and not in any meaningful way.
    Sep 2009
    764
    MAF/Speed density/Closed Loop/Highway lean cruise mode enabled is the ONLY way I will tune. Far better than speed desnity alone and 100x better than any open loop garbage.
    Sep 2009
    764
    If a tooner cannot get a GenIII MAF curve dialed in, a VE table dialed in, set up the PCM for open loop idle if desired or lean cruise and still keep a proper closed loop that will help smooth transitions and weather variations even more they need to learn what they are doing.
    Mar 2022
    Indiana
    2,951
    Quote Originally Posted by Fast4.7 View Post
    How do you enable lean cruise mode on a US vehicle? I know that there is a setting in the tune, but isn't it true that the setting has no effect? AUS cars have lean cruise capability. Lean cruise functionality is part of the code beyond what HPT can access, correct? Not trying to start anything I genuinely want to know because I'd like to have the feature.
    Sep 2009
    764
    I have been enabling it for years in P01s and P59s with HP Tuners on non Corvette stuff. Easy to do but I do not want to spell it out for fear the ability to do it will be terminated. The other option is use Universal Patcher and PCM Hammer to do it. That is open source and even has a patch that can be applied to populate the stock tables.
    Mar 2022
    Indiana
    2,951
    Ok I think I understand. Thank you.
    Sep 2009
    764
    Lean cruise will only run in a US PCM if the platform ID is AUS Holden. Should tell you all you need to know. System options table from the old platform ID need to match using the AUS Holden ID option line.
    Quote Originally Posted by bk2life View Post
    VE is a bit choppy
    No idea... this tune was in my car when I bought it.
