Open/closed loop is nothing to do with the MAF.
Put them back to how they were. Looks like I need to get a ProLink so I can log the AFR from the wideband
There are other ways to get WB signal logged. What kit do you have?
For now, I'd put it back to closed loop (can't tell you exactly what to do there, as there's still no tune file showing the changes you made to get where it is now). Log LTFT+STFT vs Commanded. See if it's still going dangerously lean when in closed loop.
Ways to get a 0-5v analog signal into the ECM:
Preferred as it could be left attached permanently, if the channel exists in the scanner for the brake booster pressure sensor (that sensor's not used on non-DOD engines). I have an E40 GMC Envoy and the scanner does not list that channel, even tried to get Support to add it to mine but no response. It may exist in later years.
Temporary connection, as you probably need both these things long-term -
A/C pressure sensor:
Fuel tank pressure sensor:
Got it back in CL, thank you for the info! I think I'll use the AC switch with bullet connectors on the WB and the AC switch to make swapping back and forth easier. I will work on that this week and I'll likely be back on here then. Thanks again for all of your help!
No booster channel for this one either. I think AC Switch will be my best bet. Once I get this all figured out I have some rats nest to fix with the fan wiring and pin it to the ECM so the computer will control it versus the derale control box that is currently used.
No booster channel for this one either. I think AC Switch will be my best bet. Once I get this all figured out I have some rats nest to fix with the fan wiring and pin it to the ECM so the computer will control it versus the derale control box that is currently used. To answer your question it's the AEM 30-0300 kit
I hate relays. This works so, so much better.
https://www.rockauto.com/en/moreinfo.php?pk=8443932
