Results 1 to 2 of 2
Thread: Having a Issue...
    Dec 2022
    1
    Having a Issue...
    Have an 02 which has a LLY swap done. It has everything from the 05, including the ECU. Runs great.
    Removed security no problem but....
    The fuel gauge is backwards now, empty is full - full is empty. Anyone know of a fix for that?
    Also the AC doesnt work anymore? If I put his stock tune back in it works, install the tune and it stops working?
    Heres the tune installed....Simon2020LLY.hpt
    Thanks, hopefully Im not the only one with these issues
    Jul 2022
    Roxana, IL
    120
    I'm having the same issue with a 2000 S10 Swapped to a 04 Trailblazer with an 05 Silverado tune.
    Did you find the issue?R_Bligh_12432_TUNE BM - (12580681) injectors+idle air -idle fuel-o2 code-p0522.hpt
    Building Automatic Transmissions since 1978
    "Most people do not listen with the intent to understand; they listen with the intent to reply."--Ernest Hemingway.
    Black 2000 S10 Base 2.2L Flex Current LS10 swap project
    Red 2000 Blazer LT 4x4 3.73 SOLD
    Red 1998 S10 SS 4.3L Deceased 10/31/2014
