Results 1 to 9 of 9
Thread: 4l60e GMC Sierra not shifting
    Apr 2023
    4
    Hi I have a 1999 GMC Sierra 4.8 4l60e and I?m having a problem where it won?t shift when I give it full throttle. When it gets to about 5,600 rpm?s it just bangs on the heat and won?t drop into the next gear. I recently got myself a mpvi3 to try to fix this problem myself any help would be useful thanks !
    Dec 2019
    MS
    566
    If you read the tune off and get a datalog of the issue it would be most helpful.
    I've seen these issues caused by poor tuning, bad transmission, or low transmission fluid level.
    Apr 2023
    4
    I will do that thank you ! I think it?s a bad tune the guy that tuned it for me retuned it twice and still the same issue with less banging in between shifts
    Nov 2006
    2,608
    It could be bad tuning.
    It can also be low on fluid. Several 4LXX platforms like a TBSS specifically will start missing shifts just half a quart low on fluid.
    Tuner at PCMofnc.com
    Apr 2023
    4
    Will check that once I?m home but I don?t think it?s that. I broke 2 transmission because of that problem both were checked a good amount of times & it didn?t do it till after I got it tuned
    Dec 2019
    MS
    566
    Are you sure the dipstick tube is seated all the way in the trans?
    100% sure the dipstick is giving you an accurate reading?
    Dec 2019
    MS
    566
    Quote Originally Posted by Alex13____ View Post
    WHat happened with the previous 2 transmissions?
    Apr 2023
    4
    Just checked and all is good on oils ���� And both other transmissions just stopped going into gear it would just rev on drive and reverse and not move.
    Dec 2019
    MS
    566
    Sounds like pump failures?
