Results 1 to 10 of 10
Thread: GPEC2 VCM Scanner issue
    Waldorf MD
    774
    Greetings folks.
    2014 Jeep Cherokee SRT8
    When using the VCM Scanner, the WB EQ Ratio (1 and 2) are showing 0.00. The STFT's show just fine and the O2 voltages appear to be fine. Because of the 0.00 ER ratios being displayed, the EQ Ratio and EQ Ratio error graphs are completely blank. Ive tried adding various channels with no luck...
    Any advice or tips? Im running version 4.10.7 with a MPVI2.
    Log and tune files attached.
    Thanks in advance!
    04252023-currentfile.hpt
    NoWBEQRatio.hpl
    Daily Driver= 2003 BMW 330xi
    Jan 2022
    904
    its a 6.4
    those wb parameters are for a different os
    a hellcat os
    *HC has both sensors stock. Your car has narrow band only
    Waldorf MD
    774
    its a 6.4
    a hellcat os
    OK Thanks
    Tuner vndetta79's Avatar
    Aug 2022
    Houston, TX
    79
    jaydubb71, are you running widebands in place of the narrowbands? Your O2 sensors are reading 0-5v which is wideband unless I'm missing something.
    Waldorf MD
    774
    Quote Originally Posted by vndetta79 View Post
    No I didn't install anything. I'm just the tuner. Yes 0-5V is what its reading in the scanner. The log file is attached in my OP. It's weird...
    Aug 2022
    Houston, TX
    79
    Quote Originally Posted by jaydubb71 View Post
    Yeah I seen your log and though it was odd. I've never seen factory sensor reading 5v on the O2's beside hellcats. Were you using external widebands to pull the data for the "WB EQ Ratio 1 & 2" channels? The only way I have those channels populate is using the AEM X series wideband with the OBDII connection.
    Jan 2022
    904
    no he is right.. they are wb
    but they must be too slow to be used for anything other than low rpm/low load cuz the os disregards once above that
    Waldorf MD
    774
    Nope. No external WB's. I'm trying to figure out a math to make the voltage convert to EQ Error now...
    Aug 2022
    Houston, TX
    79
    Not sure what the "WB EQ Ratio" channels are that you're scanning for but I take it it's the ones I've circled in the image?
    Jan 2022
    904
    just for cruising
