Results 1 to 2 of 2
Thread: Need help with VVE tuning GEN V E92 , numbers dont make sense on histogram
    Apr 2023
    5
    Hi guys,
    I really appreciate any help you can provide me regarding my VVE tuning EQ ratio histogram. I have the math parameters setup for the row axis as Pressure ratio math and i have the column as Engine Speed and the parameter is EQ ratio math, I have a AEM 03-0334 OBD2 wideband setup, the wideband is reading perfectly. Im not sure what to do with the data in the histogram because its not percentage like in my GEN 4 E38 camaro, i would just copy and paste into the VVE editor and multiply percentage by half, but this data looks to be difffrent, its not percentages and im not sure how im supposed to copy and edit the data into the VCM editor VVE Table editor. I know i cant use multiply be percentage because its causing the numbers to go way high.
    What am i supposed to do with this data? ive attached a screenshot and a log file
    As per the attached picture you're looking at the number of counts that each cell was "hit". Near the top-middle of the picture, the "C" is highlighted; click on the "A" to see average values of what you're recording.
