Originally Posted by
SiriusC1024
Yeah I know how you were doing it. I don't like STFT for VE being so close. I think of including STFT as a rough draft.
30 count. Technically it's Cell Hits Required when configuring the EQ error MAP table.
6150 rpm for WOT shift, not normal. You're probably right, though. I've done it plenty, but that's on my stuff. Technically 6000rpm is the stock limit for a 4L60E. 5500 is safe, but that's going to slow. It's your choice, of course. At least think about having it up a little higher than 5500 so we can get the VE table populated in case you change your mind. Vette has it 6000 rpm for 1-2 then 5900 for the rest.
0% pedal to 100% pedal. Yes do WOT. Do all of it to get the fuel trims populated.
Last part of your reply about the lean condition. Get that in the log, too. I'll see what I can do.
