SRT-4 / PT-GT TIP re-scale
I am getting to the point on my PT cruiser build where I need to upgrade the MAP and TIP sensors.
Upgrading and scaling the MAP is fairly obvious, but I do not see any parameters for the TIP scale.
How are people rescaling their TIPs?
Am I going to have to change to a stage 3 base tune to run the 3 bar TIP?
I would rather not disable my TIP as I am on PCM boost and would like to keep it that way.
The TIP rescales to the same parameters you define for the MAP. So you must run a TIP sensor with the exact same sensor as the MAP (or at least 2 sensors with identical voltage vs pressure characteristics).
