Results 1 to 7 of 7
Thread: rear O2 sensor switching frequency
    Jul 2019
    Baytown, TX
    118
    rear O2 sensor switching frequency?
    Hi,
    Got my 6.1 Challenger running great again, finally.
    One issue, I noticed a P0420 catalyst efficiency bank 1 code.
    Its boosted, so I have been expecting to have to deal with the cats and put in some hi flow as the exhaust manifolds and cats and mid-pipes are stock.
    Does anyone know what the switching pattern should look like for the rear O2s when the cats are healthy on these cars?
    Histograms for fuel trims ST+FT, and wideband eq ratio error are tight, bouncing around +/- 1.5 across the part throttle cells of VE...so I feel it is dialed in, on this car the front O2s are cycling maybe once every two seconds, but the rears look to be cycling too fast. I was expecting the rears to switch allot less often. I am noticing the rears switch almost as often as the fronts, although after the car warms up when idling or cruising at a constant speed the drivers side rear sensor just climbs up rich and saturates to the top of scale. It comes back low/lean if you coast (seems normal, since DFCO is enabled), then when I return to part throttle again the fronts start cycling normally... but the drivers rear maybe switches a few times before settling up to the rich side again. Does this sound like cat has gone bad?
    I think this means the cats are not doing a good job as they should, so I probably need to put some high flows cats in? which brings up my last question... who makes a good quality high flow cat that survives behind a hemi running 9psi of boost?
    2016 Chevy SS Sedan M6 SBE LS3, Whipple 2.9L, 3.625 upper/stock lower pulleys for 9.5psi, TSP Stg 3 SC Cam, ID 1050x injectors, LS7 MAF, DSX Aux Pump, DSX Flex Fuel Sensor
    2009 Dodge Challenger SRT8, 6.1 HEMI, Edelbrock E-Force TVS-2300, 9psi
    Jan 2022
    904
    high flows are not gonna fix that
    turn 'em off, build some mid pipes, and install a real o2 sensor
    Jul 2019
    Baytown, TX
    118
    Lol, I have a set of offroad mid-pipes in the garage, just reluctant to install them for a host of reasons. Real O2 sensor? I have an AEM X-Series OBD2 wideband in each bank already, and the factory narrow bands both pre and post-cat... what do you mean by a real o2 sensor?
    Tuner in Training jimmyZJ's Avatar
    Apr 2021
    14
    rear O2 sensors are not supposed to switch, if they do it means cat is bad and the PCM send a code
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    How “tight” are the LTFT/STFT @ idle after 140sec of engine run time?
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    Jul 2019
    Baytown, TX
    118
    Quote Originally Posted by jimmyZJ View Post
    Thanks, exactly the confirmation I was looking for!
    Aug 2017
    Quakertown PA
    478
    For a good hemi boosted cat, Kooks green, or go to magnum tuning . Com and buy “their’s”
    G3 Hemi Videos
