Results 1 to 20 of 20
Thread: 05 GTO Tune Help
    May 2023
    7
    05 GTO Tune Help
    Alright I'm new here so don't hound me to hard 😂 I got my GTO tuned at a local performance shop and it doesn't seem to run right, it backfires a lot and it has close to no power on the low end (have to get 3500+rpm to see the power everything else is gutless), I normally have to rev to 1500rpm and let the clutch out very slowly or else itll bog down and not go anywhere and sometimes it takes a couple cranks to start and I can tell it runs rich. I will be ordering a wideband soon so I can get the afr and see what that says. The car is tuned on E85. Ill attach the build list along with my tune file and a data log.
    The engine is a ls1 bored .030 over (Yes I know, no good...) Its got a texas speed MS4 cam, 80lb injectors, patriot stage 3 heads, I still have the stock intake manifold.
    Thanks in advance! I just want this thing to run right, got some races coming up that I wanna compete in but I'm not taking the car as it sits now. I already blew up my ls2, that's what this is replacing until I can build another engine for it.
    Mar 2022
    Indiana
    2,954
    80lb injectors? Tune says ~36lb. What injectors, exactly, are you using?
    Cylinder volume is incorrect. Should be 0.71925.
    Stoichiometric AFR 19.64? E85 is 9.8, assuming it's truly 85% ethanol.
    Spark is pretty advanced.
    Fuel trims aren't working.
    it shows he's got the double stoich, halve ifr and ivt terms for the huge injectors. needs to log injector spray time and air mass. In the log, i thought the timing was low, didn't match the tune. like it's pulling timing for some reason.
    2005 gto A4
    Darton sleeved 427, prc ls3 heads, custom cam 243/257
    Fti 3400 triple disc convertor
    553/555 N/A 839/823 nitrous on hub dyno
    Mar 2022
    Indiana
    2,954
    I don't think that's the way to do it. Should have correct injector data and realistic terms based off that.
    Mar 2022
    Indiana
    2,954
    I'm getting 10.11:1 CR and 8.08:1 DCR. I doubt there is any benefit to using e85 compared to pump gas. That trick works on the Coyote Mustangs because of the higher respective compression ratios. Using pump gas takes away the variation of e85, which is actually anywhere between e51 to e83. Just because you're able to put in more timing before knock doesn't necessarily mean more power. Has MBT been recalculated for this combo?
    May 2023
    7
    I?m not sure what all they did, I just put the engine in and sent it to them because I don?t have any experience tuning they may have recalculated the MBT but I doubt it. And I was kinda iffy on them recommending e85 because I didn?t think it would be needed for a non boost application.
    What would you recommend me change in the tune? Without a wideband I think Im fairly limited on the tweaking I can do but being new to this im unsure.
    Mar 2022
    Indiana
    2,954
    Find a new tuner or ask one of the guys on here for a remote tune. There's so much to change. Have the injector part number ready for them.
    Mar 2022
    Indiana
    2,954
    Is there a flex fuel kit on your car?
    https://www.hawksmotorsports.com/200...flex-fuel-kit/
    Mar 2011
    Ripley, MS
    1,865
    You have DTC's for your Passenger's side upstream oxygen sensor. That's preventing it from going closed loop. It'll run better once you replace that sensor.
    The double stoich/halve IFR is the best method to tune the E40 ECM with injectors that exceed the 63 lb/hr ECM injector limit. However, the engine is running lean. It will need some more tuning. Several of us can help you get it dialed in. Part throttle can be dialed in with your stock oxygen sensors, but you'll need a wideband sensor to get WOT dialed in.
    Mar 2022
    Indiana
    2,954
    Good info.
    May 2023
    7
    No I don?t have that. I just got a e85 supported pump and braided lines
    May 2023
    7
    Quote Originally Posted by kevin87turbot View Post
    Yea I gotta get that done as well. Once I get that done I?ll be able to tell more and be more comfortable tweaking stuff on my own. Would you consider running 91 on its current tune and see what happens?
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by Jtunes05 View Post
    It's not set up for 91 octane at this point, but can easily be altered.
    May 2023
    7
    What all would I need to change?
    Nov 2006
    2,745
    The drivers side O2 looks unplugged.
    IF your going to go E85 you absolutely must have a sensor to go along with it. The E content varies greatly from pump to pump and from time of year. It is not appropriate to try to do this without a ethanol content sensor.
    The timing looks OK. The VE looks like it can use some help which will give it some driveablity back.. but hunting driveablity with unknown E content is pointless right now.
    I will say.. This isn't a setup that will pick up much at all with E85. I wouldn't waste the time or effort for something that might make less than 10 rwhp. Honest.. I'll bet E on this setup might make 5 rwhp if your lucky.
    Saw someone above flag cylinder displacement being off. It is.. most 05-06's are off from the factory. I dont' think it makes any difference since displacement is wrapped up in GMVE (sorta) but I change it to the appropriate value.
    Tuner at PCMofnc.com
    Mar 2022
    Indiana
    2,954
    That timing looks ok for premium gas though? I thought it was really high.
    He stated bored .030, so that's why I checked the cylinder volume. Didn't know about the factory disparity lol.
    Nov 2006
    2,745
    Yeah I would fix the displacement but in the end I don't think it matters. GM had set them off in a lot of early LS2's. CTSV and GTO and I think Vette.. notoriously though GTO's
    28 is on the very high end for pump gas.. It might not even be making power up there.
    May 2023
    7
    I will look into the sensor today when I get home. I was pretty sure I would need an ethanol sensor but the shop said no so I stupidly took their advice. All they told me to do was change out the fuel pump so I did. I didn?t even wanna run E at all I prefer my 91 but they insisted it would run better on E. I?ll change the displacement today as well.
    So I will figure out my 02sensor and I will do some learning on tuning it on 91
    May 2023
    7
    Also if I asked you for a email tune to get me on the street faster how much would you charge me?
    Nov 2006
    2,745
    You'd have to just check the site. www.pcmofnc.com
    We go up and down on prices just to keep my workload OK. Kind of like a market price. When there is one head tuner.. we got to throttle it somehow.
