2015 z06
I updated the throttle area max from stock to 7200 and was working on vve and maf. Went wot in 3rd for a split second and it seemed fine. Went wot again in 2nd and i felt the power then it set the dtcs immediately and the car went into limp mode. It started running very poorly and i could see my wideband was maxed out lean so i pulled over. Cleared the codes and made fuel changes then started it back up and itll run fine at least not when wot. It is a 103mm granatelli TB. Are there other things I need to change should I mess with the error% under dtc p2101?p2101p2119.hpl
