Results 1 to 3 of 3
Thread: AEM Gauges X-Series Fuel/Oil Pressure Gauge (30-0301)
    Hello, is there a write up on setting up a aem 30-0301 for a p01 system in the scanner. Also would this be the best one for the aem models to use for my set up?
    Apr 2020
    37
    Recently hooked up the AEM 30-0301 fuel pressure gauge to a prolink but HPtuners is reading about half what is on the digital display (i.e. 26.8 psi vs 52 psi). I'm using the transform model option AEM (PN 30-2130-100) 100 PSIg. Any advice for this noob? Do I just create a custom transform so it matches the digital display?
    1,448
    Have you checked the voltage output of the gauge to see if the math works?
