You need to log Delivered Engine Torque (found under Engine - Torque Management section of the scanner PIDs) and Engine Speed (RPMs) for that custom PID to work. These need to be in the table display portion of the scanner.
Also, a cfg file is a configuration file that you need to open via the scanner ... double clicking it will not work. An hpl file is a log file, this can be opened just like any saved (data) log file. And finally the txt file should be openable through Notepad.
This is what is in the txt file I posted:
Converter Efficiency
([PID.4110]/[PID.12])*100
Calculated Engine HP
([PID.2701]*[PID.12])/5252
