This is probably a dumb question, but here goes anyway.
It's around -10*C here and my car has gone from 500km per tank of fuel to 300km. In warmer temps, my afr's are close to 14.7 at cruise. It seems, due to the colder weather, my afr's are down by 1. cruise is around 13.5-14 and at WOT it's at 12 (instead of my commanded 13). I understand that due to the denser cold air, more fuel is required, but shouldn't I still maintain a 14.7? Or is this error in the wb?
If I lean this out, will there be an issue? I'm still somewhat new to the whole tuning thing, so is there somewhere that I can adjust the afr's based on outside temp? or is it all based on IAT's? Would I just adjust the afr's through the IAT table?
I don't know if this was a problem when the car was stock or if this is because I messed up my IFR table when I installed larger injectors.
Thanks!
-xon
