So it's been since the 90's since I did any tuning and it was on Mazda Rotaries so I'm kind of learning everything again.
I have a new body style ram which I just installed some Stainless Works Long tube headers on. The truck also has a K&N CAI from the previous owner, and I swapped out the muffler for a Flowmaster FlowFX kit that essentially just replaces the muffler and uses the rest of the OE stuff, and a catch can.
So I've been getting a Bank 2 Cat efficiency code, since the headers. Below are the changes I've made to correct for this.
Engine - Fuel - Oxygen Sensors - Feedback - Closed loop Enable - Enable Delay (entire table) X 1.4
Engine - Fuel - Oxygen Sensors - Feedback - Closed loop Enable - Enable Delay Rear (entire table) X 1.5
My understanding is this should lengthen the time for the sensors to heat up for proper function.
Engine - Fuel - Oxygen Sensors -Transport Delay - 02 Bank 1 Airflow Delay (entire table) X 1.5
Engine - Fuel - Oxygen Sensors -Transport Delay - 02 Bank 2 Airflow Delay (entire table) X 1.5
My understanding is this should make up for the additional distance for the sensor since the headers take it further down the exhaust stream.
And I also adjusted: Engine - Airflow - Electronic Throttle - Ramp Rate - upped it from 0.020 to 0.050 (Trying to play with the throttle response)
The truck is my everyday driver when I'm home, I have several other Mods I intend to do but the overall goal is to pass emissions here in TX and see some benefit from tunning.
My questions:
1 - Should I have just increased the temperature on the 02's or do a combination of both?
2 - The Transport Delay - I can't seem to find how to figure the math on this delay. Say the original sensor was 7"'s away and the new one is 14"'s away, Double the time or figure the percentage of change and use that for the multiplier? Also does the wired extension play into this number since the length of wire is now longer.
3 - Neural Network - Seems like this is best to leave on since it helps to clean up the little stuff.
4 - Wideband sensor - Which side is best for it or do I need to do both? Really didn't have this issue with 2 rotors lol some not sure here.
I'll start with the above, I do have plenty more questions.
