i was going through the startup and it has this info below
Idle airflow: Log the STIT and LTIT and add the 2 together. With a manual you will use LTIT in gear all the time, autos will use the respective LTIT depedning on the gear selector position. Add the 2 values together (or make a custom histogram) and make chagnes based on ECT. Say 30*C STIT is -0.30 g/sec and LTIT is 0.10 g/sec, you want to subract 0.20 g/sec from the 30*C cell in the idle airflow table. It is important to make these changes only from a cold start as they will give the most accurate data. Make sure it is logging and you make corrections in metric as it adds better resolution. For starters, adding 2 g/sec to the table before initial start up after a cam can help idle.
so i go and log the idle for a bit and for STIT at 30* i have -1.43 and for LTIT i have -3.00 g/sec, do i all the whole numbers as well or only what is after the decimal.
