Results 1 to 5 of 5
Thread: Help please
    Apr 2023
    10
    Help please
    hi all
    itry to use vcm error for tune maf and ve
    i have aem wideband and made all steps they need
    i made all canclellations for my car
    DFCO
    CATS
    O2
    LTFT
    DYNAMIC
    CL
    DOD
    FLEX FUEL
    and when i start scanner no error info record at all ?
    Did you add the wideband to your channels?
    Apr 2023
    10
    yes and its work but the error nothing
    Apr 2023
    10
    also i change parameter from afr error to eq ratio error is same problem
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    509
    First, change your cell hits from 50 down to 0 to see if that populates data.
    If not, then you need to look at your custom math and ensure that all PIDs you are referencing are in your channels list.
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
