First thank you to everyone, my 2007 c6 z06 big cam, twin turbo, methanol breathing monstrosity runs, and I drive it daily thanks to all the help from this forum.
I have been working on getting WOT dialed in, and I noticed that my MAF drops off far before I ever let off the pedal. this is a 7 second clip, at 5.23 the maf starts dropping from 409g/s and gets all the way down to 180g/s before I actually let off the throttle, but Map holds above 140, cylinder airmass holds at 1.24 and boost holds above 5.5lbs.
I am completely confused by this, am I just tripping and the PID's are delayed and this is normal, or is something going wrong? its hard to tell from the drivers seat, cause it breaks the tires loose....always lol. I figured if I was blowing the boost out the manifold the map would drop. Could I be blowing out the spark (I am switching to br7fe's today), it only happens when I get around 4500 rpm and higher?
any advice or help is appreciated, and please ignore the .9 knock at the end, I had my methanol off. thank you in advance for any help with this.
WOT maf drops off.hpl
5-19-23.hpt
