Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 110
Thread: stumbles on cold start
    Tuner K Rob's Avatar
    Apr 2021
    Oklahoma City, OK
    88
    01' Camaro BTR Stage 4 cam 233/248 .630"/.615" 111.5+2.5
    Cold start seems to be running extremely rich - any help would be appreciated !Tune1.hptkevinidle.hpl
    2009 Pontiac G8 GT - VCM otr intake, underdrive pulley, Kooks LT's no cats to Kooks mufflers, LS7 maf, 3.45 gears, stall, cammed
    2014 Chevy SS - Rotofab CAI, LS7 maf, Kooks LT's no cats to factory mufflers, flex fuel sensor, cammed
    Mar 2022
    Indiana
    2,944
    The log is a hot start. Regardless, commanded EQ is correct here. Look at the values for Open Loop EQ and Afterstart Initial Adder. It supposed to be doing that. The only problem is you can't tell if it's actually .85 lambda because there's no wideband data to verify.
    The correct thing to do is tune the airflow side of things. Looks like it's not quite there.
    Turn on LTFT's btw.
    Apr 2021
    Oklahoma City, OK
    88
    tune the airflow side ? can you be more specific - Thank You !!
    I will turn on LTFT's.
    Mar 2022
    Indiana
    2,944
    Yes. Start by tuning the VE table. There are a bunch of threads on how to do this.
    Personally, I'd ditch the MAF and run it in SD entirely.
    Sep 2022
    indiana
    24
    Quote Originally Posted by K Rob View Post
    Go to goat rope garage and watch his Gen 3 videos on MAF and VE tuning. that should get you to where you want to be.
    Apr 2021
    Oklahoma City, OK
    88
    Quote Originally Posted by horsepowerguru View Post
    Done
    Apr 2021
    Oklahoma City, OK
    88
    Here are a couple cold start logs
    Mar 2022
    Indiana
    2,944
    Got the tune to go with the logs or is it the same tune?
    Apr 2021
    Oklahoma City, OK
    88
    Same tune
    I can get it startup with opening the throttle blade more but it idles way too high and the iac is zero as well.
    Mar 2022
    Indiana
    2,944
    See if this helps with the startup. Change the cranking VE. There's a few things going on, but try this first.
    Apr 2021
    Oklahoma City, OK
    88
    I will and report back - Thank You !!!
    Nov 2006
    2,742
    Same tune
    This looks like a stock VE table. You are going to get a good result until that is dialed in and that cam may never get along with that size cam. Got to have a wideband with a cam that large too. The narrow bands and the fuel trims can drive itself too rich with a cam that large.
    Tuner at PCMofnc.com
    Apr 2021
    Oklahoma City, OK
    88
    That helped - current log attached
    Apr 2021
    Oklahoma City, OK
    88
    Okay - got to give it a shot - Thanks !!
    Apr 2021
    Oklahoma City, OK
    88
    i opened the throttle blade to get it to start - iac counts are zero but it idles too high as expected - closed the blade to get somewhat desired rpm.
    Mar 2022
    Indiana
    2,944
    Looks like idle really stabilized after CL enabled. It was running rich during OL. Try the OL and idle changes in the attached file. Get to VE, which it needs, after idle is stable.
    Also, IAC counts are a little high. Try doing this.
    https://thetuningschool.com/blogs/ne...elearn-process
    Apr 2021
    Oklahoma City, OK
    88
    I have done the relearn a couple of times already - hopefully with the changes you have made it will idle soon without opening the throttle blade excessively.
    Apr 2021
    Oklahoma City, OK
    88
    Well this is the best startup so far - it fired right up, struggled the whole time it seemed but it never died. Pretty sure its still rich on startup.
    Thank You for taking the time to help - current log attached !!!!!!!!
    Mar 2022
    Indiana
    2,944
    Should tune the VE.
    Engine Diag>Airflow>Mass Airflow Sensor set MAF Freq Fail High to 0Hz
    DTC's are already right. SES light will be on, but that's because of MAF 0Hz.
    Engine>Fuel>Oxygen Sensors set LTFT to Enabled and Min ECT to 140F. LTFT Boundaries>RPM Lo=900 Mid=1400 High=2200.
    Post a log with those setting applied. Populate more cells in the STFT and LTFT tables of VCM Scanner. Try driving around a bit.
    Apr 2021
    Oklahoma City, OK
    88
    Should tune the VE.
    Perfect will do - Thank You once again !!!!!!
