Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 110
Thread: stumbles on cold start
  1. #21
    Tuner K Rob's Avatar
    Apr 2021
    Oklahoma City, OK
    88
    Well I applied the changes and now the car wont start :-(
    2009 Pontiac G8 GT - VCM otr intake, underdrive pulley, Kooks LT's no cats to Kooks mufflers, LS7 maf, 3.45 gears, stall, cammed
    2014 Chevy SS - Rotofab CAI, LS7 maf, Kooks LT's no cats to factory mufflers, flex fuel sensor, cammed
  2. #22
    Apr 2021
    Oklahoma City, OK
    88
    had to use the pedal to start it
  3. #23
    Mar 2022
    Indiana
    2,932
    Just checking are you running factory injectors?
  4. #24
    Apr 2021
    Oklahoma City, OK
    88
    No I am not
  5. #25
    Mar 2022
    Indiana
    2,932
    Well then that makes a lot more sense lol. That mod wasn't listed in the first post, but I still should've asked sooner. Give me the part number please.
  6. #26
    Apr 2021
    Oklahoma City, OK
    88
    It?s the white injectors from Grand Prix GXP. 42lb
  7. #27
    Apr 2021
    Oklahoma City, OK
    88
    Stock short block LS1
    TEA light ported Trick Flow 220s
    64cc chamber (10.5:1)
    BTR stage IV cam 233/248 .630/.615 111.5+2.5
    92mm intake and throttle body
    E85 42lb injectors and Racetronix 255 pump, with hotwire kit.
    Kooks 1 7/8 headers 3 inch collectors. 3 inch y pipe to 4 inch Mufflex exhaust Magnaflow muffler.
    Th400 reverse manual valve body. With trans brake.
  8. #28
    Mar 2022
    Indiana
    2,932
    It'd be easier if you would read off the part number.
    The GTP had 42lb (@4 bar) white injectors. Are you sure it's the GXP not GTP?
  9. #29
    Apr 2021
    Oklahoma City, OK
    88
    I apologize - 24508208
    Thank You for your time !!!!
  10. #30
    Mar 2022
    Indiana
    2,932
    Here you go. Every change applied up to this point (cranking VE, OL EQ table, SD mode) plus:
    Engine>Fuel>General
    Engine>Fuel>Transients
    Engine>Spark>Advance>Cranking
    Idle RPM back up since, after re-reading, you put on an underdrive pulley. Have to keep the voltage up.
    Clear fuel trims with VCM Scanner>Diagnostics & Special Controls. Flash the tune. Run it and get a good log of fuel trims.
  11. #31
    Apr 2021
    Oklahoma City, OK
    88
    Copy that - Thank You once again for your help !!!!!
  12. #32
    Apr 2021
    Oklahoma City, OK
    88
    Current log
  13. #33
    Mar 2022
    Indiana
    2,932
    Are you sure that's the tune I uploaded? Looks like it's still trying to idle around 750, and the fuel trims are the same as before.
  14. #34
    Apr 2021
    Oklahoma City, OK
    88
    I believe so - I will try again in the morning - I thought it was struggling to idle as well as rich as usual.
    Thanks !!!!
  15. #35
    Apr 2021
    Oklahoma City, OK
    88
    2 logs - 1st one cold start
    2nd is cruising
    Thank You for your time and patience !!!
  16. #36
    Mar 2022
    Indiana
    2,932
    Let's see what happens with this:
    VE
    Idle Spark
    Be sure you're resetting fuel trims after flashing a tune. There's LTFT reset, but to the right of it is regular fuel trim reset On/Off.
  17. #37
    Apr 2021
    Oklahoma City, OK
    88
    Okay - great Thank You will do
  18. #38
    Apr 2021
    Oklahoma City, OK
    88
    Updated log
  19. #39
    Mar 2022
    Indiana
    2,932
    Alright here's updated VE.
  20. #40
    Apr 2021
    Oklahoma City, OK
    88
    Good morning and Thank You !!
