Page 6 of 6 FirstFirst ... 23456
Results 101 to 110 of 110
Thread: stumbles on cold start
  1. #101
    Mar 2022
    Indiana
    2,944
    No log?
  2. #102
    Tuner K Rob's Avatar
    Apr 2021
    Oklahoma City, OK
    88
    got sidetracked - here is current log
  3. #103
    Mar 2022
    Indiana
    2,944
    Here you go. MAF adjusted based on log. A few other adjustments. Done with airflow on both sides, so returned to running factory MAF/SD strategy. Hi and Lo spark tables available.
    That's all I can do until you get a wideband in and the speedometer fixed. When you're ready to continue post here and PM me when you do.
    How's it running? Hard to tell about things like brake pedal feel (vacuum), idle sound, and shifting. As far as idle, One thing you might try is lowering the at-temp idle a little bit. Don't want to go so low that the headlights dim (underdrive pulley) or the off-idle transition stumbles.
    This was a challenge, but we got it. Thanks for your patience and hope your ride is a lot more enjoyable now.
  4. #104
    Apr 2021
    Oklahoma City, OK
    88
    I couldn't be happier - it fires right up, idles great and I can lower the idle if needed. You are awesome and I can't thank you enough for your time and patience !!!!!
    Will get the speedometer working first and then a wideband but will stay in touch - Thanks again !!!!!!!
    2009 Pontiac G8 GT - VCM otr intake, underdrive pulley, Kooks LT's no cats to Kooks mufflers, LS7 maf, 3.45 gears, stall, cammed
    2014 Chevy SS - Rotofab CAI, LS7 maf, Kooks LT's no cats to factory mufflers, flex fuel sensor, cammed
  5. #105
    Mar 2022
    Indiana
    2,944
    Excellent. I'm happy if you're happy.
    I forgot to mention one important thing. Since it had been running really rich the oil has probably been contaminated with gas. Does terrible things to the film strength of the oil. Should do an oil change promptly.
  6. #106
    Apr 2021
    Oklahoma City, OK
    88
    Oh okay - had been thinking the oil pressure seems a little low for my liking and what is the rev limiter set at ?
  7. #107
    Mar 2022
    Indiana
    2,944
    6300. I didn't change that. Just the hysteresis of rev limiter. Re-enable was set at 6299. 1rpm won't stop it from over-revving. Changed it to 6250. Are you wanting something in particular done to it? Should be able to change it there and then make sure the trans still shifts before redline.
  8. #108
    Apr 2021
    Oklahoma City, OK
    88
    I think the cam is good up to 6800ish rpm
  9. #109
    Mar 2022
    Indiana
    2,944
    Connecting rods and bolts have their limits. So does the transmission. Might check on that.
    Shouldn't be going up that high until you can verify correct AFR during PE. We haven't done that yet.
  10. #110
    Apr 2021
    Oklahoma City, OK
    88
    Oh okay sounds good.
