This is round 58 of killing all the gremlins on a new build. Blindsquirrel is likely tired of all my threads.
I think most are gone but the new trans is either slipping or something is wrong in the tune not allowing to build boost.
Smoke tested an no boost leaks, 14in vac, correct spring installed in bov.
7psi spring in the wastegate, fire ring is in there, both referenced at the brake booster port of a truck intake. (manual brakes)
No exhaust leaks.
My first test drive, the car was really quick to 35mph in the neighborhood, bov was very loud.
I then took the advise of others and installed an intercooler losing my hood latch.
Since then, I drove it to the alignment shop easy driving. From there it never felt the same as the first day. MAP log never breaks 100kpa. bov is quiet. Passing gear does nothing, 3rd almost feels like its gone trans maybe has 40 miles on it.
5.3 L33, p59 DBW, 50lb (injector data from BS), Filtered 7875, Sloppy best cam, 3bar map from efisource
4l80e, P/N only shifter, 28-3200 converter, 60psi boost referenced fuel regulator
functional PCV system, AEM 30-0300 wideband only, 4.5 to 3.5 open downpipe exhaust.
Most of this file was taken from sloppy's dontbsme tunes.
nothing when floored.hpl
test11wsloptransswap.hpt
I dont feel confident with the only dyno tuner local to me.
Wasting $800 on a dyno session, if the $2000 rebuilt transmission is junk doesnt sound like a good time.
I think thats it, this is my first HPT experience. thank you for your time.
