I am working on tuning my over 200k mile stock 2014 Silverado 1500 L83 5.3L. It is a stock truck with an Exhaust on it. I have an MPVI3 and an Innovate LM2 wideband that I have built a decently accurate MAF tune with while learning from both here and Youtube.
I have also done some small things, like disabling DOD and changing some TCC lockup settings as recommended by a lot of sources for these pickups.
I began what I felt was the next step, which would be tuning a VVE/Speed Density map. I disabled DFCO, forced Open Loop, disabled MAF as recommended in Goat Ropes Speed Density process. I put some miles on doing quite a bit of logging with the stock VVE table to gather data. Once I gathered and reviewed the Log I felt that I should do a bit more research before I implemented the changes to my tables as some of them seemed relatively dramatic for a mostly stock pickup. I tried to clean up the data a bit. I set a filter do only show data greater than 0% accelerator pedal position, as well as a filter to discard anything over 1.2 EQ on Lambda, just like I did with my MAF tune to filter out of a lot of the lean on decel readings. I still have quite a few tables that were over 15% rich on the higher RPMS, especially at low MAP Pressure. I have PE enabled, but it seems the common recommendation is to Tune with PE enabled.
If someone could please look at my logs and recommend how I should proceed I would greatly appreciate it.
Do I implement the changes from this log and begin tuning? Do I skip VVE tuning on a stock high milage truck like this and move on to Spark tables?
Thank you for any responses, I have attached the Log file and the Tune I used with it.
