I appreciate your advice & have added those channels to my Scanner. Those will be part of fixing the knock problem, correct? I think I understand the suggestion to up the MAF table, you are speaking of the MAF Calibration tables, Airflow vs Freq Low & High, correct?
If I tweak the MAF table & continue with the MAF tuning will dialing that in better help with the knock issue or do I need to deal with the knock directly first? As you can tell the knock issue has me concerned.
Thanks!
