A couple issues during VE tuning on this E67 427.
1. I have set MAF fail to 0 hz and P101,102,103 to MIL on first error. I go for a ride and get my LTFT's. When I return and let it coast to idle it goes into REP mode and barely idles. I have to clear the only code P106 to get it to run again to get back home. I was getting a P068 error but I change that to no error reported. I think I am answering my own question: raise the airflow delta diagnostics???
2. The first time I logged LTFT's they were only -5% or so. I'm logging .4 to .7 kPa vs 2000 to 4000 RPM. I multiply % into the manifold open VE table ( I can confirm the % changed correctly) and calculate coefficients. I flash and warm up fully again and go for another ride. Now the LTFT are +10% in a bunch of areas....and probably correlate to zones. I've not seen this happen before. Usually I get the correction I put in the VE table.DonsRegalModified427_R14.hpt
Appreciate any insight.
