Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: E67 REP during VE tuning
  1. #21
    Tuning Addict
    Jan 2015
    6,787
    I still dial it in even when I've gotten them from customers that were zeroed - I populate them and dial them in no matter the injector size. No doubt there are other tables at play, but if we can't edit them and can edit this, then I edit it to correct it. I always thought people were sending me files zeroed out where they had zeroed them out. People zero them out based on bad info from years ago discussed on the subject so I never thought much of it - I just dialed it in. We decided it was best to dial it in years ago after seeing the negatives of having it zeroed. Heck Jslic is the man that discovered this table then - I worked with him on it along with several other tables that are in hpt today.... I used efi and sct to change tables then read them out with hpt and sent them to hpt, so I understand the importance of this stuff If setup right you can literally hot soak and make back to back passes with a 1000hp car getting damn near identical passes each time. Trust me - you don't want to dial it in - it's up to you, but it can make them go pretty lean when they get hot.
    ~Greg Huggins~
  2. #22
    Sep 2015
    13
    Thanks again. This is how the VE turned out. That VVE assistant really helped.
  3. #23
    Tuning Addict
    Jan 2015
    6,787
    You can't ask for much better than that
    ~Greg Huggins~
  4. #24
    Nov 2006
    2,722
    Injector offsets should come from the injector manufacturer just like all other injector data.
    I really have no idea what you mean about a 1000hp car not being repeatable? I do not have that issue. Worse possible case that amount of offset is so negligible to the final fueling at high loads. Its really idle and decel were you would notice improper injector data.
    At WOT
    18ms + .3ms offset = 18.3ms 1.6% difference in fueling
    At idle
    1ms + .3ms offset = 1.3ms 30% richer.. plug fouling territory.
    Tuner at PCMofnc.com
  5. #25
    Tuning Addict
    Jan 2015
    6,787
    Dialing it in at an elevated idle works and keeps wot afr's dialed in for hot itt's or cold itt's. You're welcome to do and test.
    ~Greg Huggins~
