Originally Posted by
ramermanz28
Chad, thank you for responding. I will add the PIDs you are referring to and get another log to post. Are you saying to add a chart that logs MAF, VE, and Dynamic airflow on one graph?
Which log are you looking at (1) or(2)?
I'm not sure what wiring issue would cause this? It could be the EQ ration is off based on the AEM wideband, I notice that sometimes when I first give it gas or let off the gas the AEM wideband will go high. It might be because of the sensor location. I have it in located in the X-pipe fitting to be able to get the average of both banks. I'm not running cats. Maybe I have the sensor too far down the exhaust?
Thank you, Robert.
