Results 1 to 4 of 4
Thread: cold take off
    cold take off
    I was having this issue where if i didnt let the car run for a bit it would just not have any power and felt like it was limiting itself or pulling alot of timing out. Usually i let it run for a few minutes before taking off so never noticed this until I needed to leave in a hurry.
    So i logged all the spark related stuff and noticed the startup retard was seeming to cause it. I zeroed out the catalyst heating multiplier and it seemed to help
    here is what i logged
    cold drive.hpl
    tried again this morning and no issues driving off cold. noticed some knock on take offs though and still got some bucking/surging at low speeds i need to address but its getting there. here is log and tune from today if anyone wants to take a look and give me advice or suggestions...or tell me im an idiot haha
    23-05-25 17-29-16.hpl subaradosdcl40startupmod2.hpt
    13,565
    What are the mods?
    I think your idle timing is too low at 15 degrees, most like around 20-22 degrees.
    Your open loop EQ ratio is 1.00 for every cell, if you look at a factory tune they command a richer fuel mixture on a cold engine because they tend to run a little better while warming up.
    lq4
    706 heads
    228/230@ .050” .585” 112 cam
    12613412 injectors
    ls1 intake
    ok ill try to up the timing some. i had it around 20 before and playing with timing i didnt see much change in kpa so i left it there.
    ill change the eq also
    Nov 2017
    Indiana
    329
    did these changes fix your issues?
