Results 1 to 5 of 5
Thread: throttle position not matching desired after id1050x install 14 CTSV
    Feb 2018
    810
    So I just replaced my I.D. 850s with some 1050s and now i've noticed my throttle position no longer matches my desired/commanded position. All I did was switch the injectors and input the data into the tune, else. What could cause this mis match? With the 850s they always were about identical to each other. 103 NW Throttle body is installed on my car. This was on the car when I had the 850s too.
    throttle pos not matching desired_commanded.hpl2.35 pulley, ID1050Xs, CURRENT TUNE.hpt
    Feb 2018
    810
    So I found there are two different "throttle positions" one has 1 blue arrow to the left and the other has 2 blue arrows (1 blue arrow are ECU specific ones I guess?). You can that the one with 1 blue arrow is matching perfectly with desired/commanded. The one with 2 blue arrows is off. Soooo should I just use the 1 blue arrow (ECU specific) one and ignore the other one?
    Oct 2014
    Moscow, Russia
    197
    HPT team does not differ throttle area and throttle position. They call everything as throttle position.
    2.7% - area
    7.5% - position
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Feb 2018
    810
    Quote Originally Posted by verlon View Post
    2.7% - area
    7.5% - position
    thanks! Appreciate it, I never knew that
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    481
    Quote Originally Posted by sgod1100 View Post
    ...one has 1 blue arrow to the left and the other has 2 blue arrows...
    1 arrow means the PID is a broadcast parameter. The ECM broadcasts the data on the CANBus network on its own so any device can read the data.
    2 arrows means the PID is a polled parameter, meaning you (or the HPT scanner) have to request the data first from the ECM, then wait for it to send it over the network.
    Not sure which one is faster as there is no guarantee how frequently the broadcast parameter is sent, nor is there any way of knowing the latency when requesting a parameter. Most likely dependent on a bunch of factors at any given moment.
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
