Results 1 to 3 of 3
Thread: trouble with warm starts ls7 need tuning advice
    2007 C6 Z06 Twin Turbo, big cam. the high torque aftermarket starter, and battery have no issues, they can crank the car without problems when its hot, there's no slow crank or anything like that. If i pedal it a few times, eventually it will fire and then has no issues. Hence the car can crank without issue, and once it sees the gas and air mix it wants it fires right up.
    I have noticed that maf is lowest in the warm starts log, and iat is highest. the turbos have a direct filter attached and they are in the engine bay. I have tried lowering cranking spark, lowering cranking fa, and raising the startup airflow, and there seems to be no changes with any of these adjustments.
    my afr commanded is 1.25 during warm crank, around 1 during semi warm and .25 during cold crank, im thinking not enough gas being commanded?
    I have 3 recordings, cold, almost warm, and completely warmed up. the car only long cranks in completely warmed up. I am open to suggestions and advice, thank you in advance for any help with this.
    latest (2).hpt
    long cranking when fully warmed up driving for 20 minutes.hpl
    cold start no issues immediate fire.hpl
    semi warmed up started just fine.hpl
    Tuning Addict
    Jan 2015
    6,802
    What's actual rail pressure when you're cranking it hot? Almost looks like pressure lock or lack there of especially when you can keep cranking and giving it that much air without it even trying to fire. Injector pw's are very low during cranking - if fuel pressure checks out good with no bleed off and not too high then try increasing crank fuel especially where you have .8's.
    ~Greg Huggins~
    Thank you very much, I will double check, I had a mechanical gauge on the rail recently and it read 58 after being primed, but I've never watched it while cranking. I appreciate the help
