Hey all, new to the forum. I have a Gen 3 5.3 with an LSA super charger mated to it. Deka 80lb injectors in it, running at 58psi fuel pressure before vacuum line attached. Also have a t56 magnum f mated to it. I?ve been working on the tune with my coworker who used to run a dyno at a past shop with very little ls experience or go tuners. The car runs pretty solid at idle, AFRs look good while driving normal through all gears. The issue I?m having is that it seems to not be making any boost at all. When I try to hit boost ranges it falls flat on its face, AFRs go super rich, I can see like 2-3 psi show up on the gauge quick when it happens as well. I have attached a picture of what happened on the scanner when it cut out and will post my tune file in a few when I hop onto my laptop.
Thanks everyone and anyone in advance!
