C6 Corvette, LS2, E-Force Supercharger, 10 lbs. Boost, E85/DSX Flex Fuel, 227/234 114LSA CAM, 225 as cast PRC Heads.
I am attempting to calibrate/scale my MAF using my NGK/AFX Wideband by creating a Graph/Histogram that logs the error between the Equivalence Ratio Commanded (lambda) and the AFR (lambda) displayed by my NGK/AFX Wideband. In order for my NGK/AFX Wideband to display as a lambda value in the Scanner, I had to Transform the output of the Wideband. When data logging, the Equivalence Ratio Commanded Channel displays in lambda and the NGK/AFX, channel MPVI2.1 -> NGK - AFX displays in lambda. I can see the error between the commanded and actual lambda values, I just can't seem to get the Graph/Histogram to work. I believe my issue is with the Math Parameters. Does anyone know what the Math Parameter Expression should read. The ID for the MPVI2 (wideband) is represented as V and not Lambda. I do not know how to modify the Math Parameters Expression for the MPVI2 input (NGK/AFX Wideband).
Does anyone know how the Math Parameter Expression should read. The following is what it looks like at the moment:
100 * ([30011.10] - [50118.238]) / [50118.238]
To Transform the NGK/AFX to read in lambda, I used the following:
Function: (Input/10.416) + 0.618 = Output
I have searched but have not found any answers or anything that seems to work. I am hoping that someone has worked through this issue and has an answer for me as I have not been able to figure this out on my own.
