Results 1 to 20 of 22
Thread: Need help with a burble tuning.. a mild one
    May 2023
    20
    I?m tuning my Dads CTS-V and he wants a mild burble tune (I?m new to tuning) so I did it and it sounds really good. Only problem is when he is at 3k rpm in 3rd or 4th gear it surges kinda bad..I'm thinking it?s the max torque timing or main timing, I did the minimum spark base, idle adaptive spark base,
    coastdown.
    Sep 2022
    indiana
    24
    do you have a tune file and a log?
    May 2023
    20
    I gotta look for the log
    May 2023
    20
    Quote Originally Posted by horsepowerguru View Post
    Here is the log and file.
    Jul 2018
    DENVER CO
    20
    personally i would put those tables all back to what you had before and make it burble through the DFCO raise the [ECM] 18698 - Minimum RPM Rate to Disable DFCO: to 4000 and adjust the timing in both entry spark and exit spark and CFCO timing
    May 2023
    20
    I will try that. Thanks
    May 2023
    20
    What kind of entry spark and exit spark should I go?
    Although you'll find that methodology you have in the tune will work for produce burgling, it will also create jerking as the driver goes from 35* of timing and hits the zero timing area. I dont like to pull timing like that from the main tables to create gurlging.
    May 2023
    20
    I tired that it give it a nice rumble. Do I take away timing under 4k or over?
    Jul 2018
    DENVER CO
    20
    Lower your entry blend time by multiplying.5 and take your entry spark down to 5 degrees from 4000 down. As for your exit spark it can also go to 5 degrees from 4000 down.
    May 2023
    20
    Alright I will try this thank you
    Nov 2018
    Georgia
    81
    you only need to change the spark coastdown for burble put the base and octane tables back as found. your surge is
    from 0 spark in octane tables
    May 2023
    20
    Thank you but I got it to work through the DFCO
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    210
    Quote Originally Posted by Manny16 View Post
    Hope he dont care about replacing o2 sensors.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
    May 2023
    20
    The DFCO is gonna mess the o2 sensors up?
    Mar 2021
    210
    Quote Originally Posted by JayRolla View Post
    No the fireballs igniting in the exhaust that makes the burble sounds will. Also will burn up cats if he still has them.
    May 2023
    20
    Ohh phew had me worried for a sec it?s not running that rich, no cats
    Mar 2021
    210
    Okay, as long as its not popping and banging like the bmw boiz with their stage 5 burble tunes.
    May 2023
    20
    Jul 2018
    DENVER CO
    20
    in my experience the popping and banging happen when the cfco is set to not kick in. [ECM] 2299 - CFCO Enable ECT: ECT must be above this value to enable CFCO is set to 400 degrees it allows the fuel to continue flowing till the dfco kicks in that is when you get all the popping, banging and backfires that would kill an O2 sensor or cats. on manual cars
