Results 1 to 11 of 11
Thread: running lean with straight pipe and cold air intake and wide band. 5.3 lm7 02 chevy
    May 2023
    9
    unsure how to resolve this issue or what keeps causing my engine to start running super lean out of the blue,current tune.hpttest drive with 02 reading.hpl
    Jan 2015
    565
    Looks Like it runs lean from the very start on this data log. Reset your fuel trims and plot wide band error percentage. Take the error and make changes to either you mas airflow or ve table to correct.
    13,564
    If it's that lean with such minimal mods you have other problems.
    Like low fuel pressure, exhaust leaks before or directly after the o2 sensors or a vacuum/intake leak after the MAF sensor.
    I've never had a cold air intake on the GEN 3 MAF sensors cause massive lean codes.
    May 2023
    9
    plotting wide band error percentage
    Quote Originally Posted by reubone View Post
    Im unable to get my channels list to data log commanded afr. anyway to work around this so i can get my afr percentage tables filled?
    May 2023
    9
    ive double checked everything u stated up there and it all seems to check out, i have no current exhaust leaks, intake leaks, or low fuel pressure. Just a little concerned about running to 17 afr not shooting for fuel economy exactly. I also cant my commanded afr to pop up in channels list any idea how to work around this to fill my afr error tables so i can tune via maf? Im relatively new to tuning.
    Nov 2017
    Indiana
    329
    why dont you have any O2 data?
    May 2023
    9
    should be 02 data under my graphs
    Mar 2022
    Indiana
    2,930
    What's so hard about this problem? OL-Fault. B2S1 O2 is dead.
    Feb 2020
    georgia
    18
    see im having some simliar issues but worse
    Dec 2019
    MS
    567
    Quote Originally Posted by Bobers9 View Post
    Did you remove the passenger side oxygen sensor to put your wideband in?
    Sep 2009
    764
    I have seen a simple missing OE air filter cause a GEN 3 style MAF and 0411 PCM setup to peg the fuel trims as well as hesitate and bog.
