Results 1 to 17 of 17
Thread: Stuck on start up issue
    Jun 2022
    Canada
    61
    So I have been slowing working through tuning this thing. Now I have an RPM swing on start up but only during the " start up" sequence. The 90 seconds it idles high before it idles down is the only time it does this. Any suggestions would be appreciated
    The current tune and log is attached. Cold start and a hot start at the end of the log. Currently running in OL, Fuel trims at start up are low 14.xx
    June 1 HRT Jeep.hptjune one start log cold -hot.hpl
    Sep 2021
    Yorba Linda
    80
    I remember you posted on my thread of the exact same issue .I?m still having the same issue so if you get your resolved i?d love to hear how they fixed it .. I have a 1,400 rpm high idle and slowly drops down no matter if it?s hot or cold
    Jun 2022
    Canada
    61
    I gave up on that problem. Now I get more of a surge but just in that first 90 seconds.
    Jan 2022
    903
    yeah it looks like it has a radical cam
    especially when warm
    something in the airflow is off but weird how it goes away
    Jun 2022
    Canada
    61
    Its got an HRT stage 2 cam.
    So far I added fuel to the FA cold start table and it made it a bit better but still needs help somewhere. I am assuming the air flow tables.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    didnt look at the log yet.
    But isnt it so, that the ann takes over at 12 sek and use the adapted values for fuel trims ? the gpec2 do so.
    Jun 2022
    Canada
    61
    This is the much older NGC4 so no NN...
    Jan 2022
    903
    it uses open and closed loop tho
    Aug 2021
    Yorktown VA
    196
    Definitely a fueling issue...
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
    Aug 2021
    Yorktown VA
    196
    Your manifold pressure seems to be relatively steady throughout. But your fuel mass, injector pulse widths, and both bank's sensor 1 O2 sensors are all going ape sh*t right from the start. Might look at your part throttle spark table as well, mainly the transitioning from 55 to 60 Kpa range and vice versa in your idling columns.
    Jun 2022
    Canada
    61
    Quote Originally Posted by Spray-Cam Hell-Ram View Post
    Shoot ya I forgot I put a big dip in the timing there, that was an experiment for a different issue and I missed putting it back. However the O2s have been all over the place for quite some time, I assumed it was because of the lumpy cam and choppy ish idle timing....
    May 2017
    6
    its program to do that look in ecm 35573 base set point you can adjust from there
    Jun 2022
    Canada
    61
    Quote Originally Posted by fastrt09 View Post
    Table not available on NGC4..
    Jun 2022
    Canada
    61
    So start up rpm swing/surge is better after adjusting start up air flow and fixing my pt spark table. Air flow made the biggest change. B1 and B2 sensors are still weird at the 70 ish second point of run time then go more normal once I started driving. I think maybe because engine is still cold and a bit rich its messing with the sensors until everything is hot
    June 6 cold strt and log.hpl
    june 6 fix.hpt
    May 2018
    Germany
    586
    Torque or airflow settings….not to forget….
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    Quote Originally Posted by f.creek-ranch View Post
    They’re out of wack on the ngc to start
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    I have a similar issue since swapping to e85 in my hellcat with the injectors to support it. First 90 seconds the car surges its brains out until it gets to closed loop fueling then it idles like its stock. Should I add start up airflow or fuel? havent played with either yet
