Results 1 to 11 of 11
Thread: Ram 5.7 with 6.4 non MDS cam
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    So far...
    I took in a 6.4 non MDS cam in our Ram 5.7 and delete all MDS.
    I know its not the perfect option for a truck. The big different seems the LSA from 114 to 121?
    Now Im not sure what values to set in the PCM. Should I use the 2500 Ram data - uses 114 LSA or the 6.4 shifter data from the Charger ?
    I think the intake centerline is different, so i have to substract 8-10? like in the GPEC2.
    Jan 2022
    909
    Quote Originally Posted by f.creek-ranch View Post
    Now Im not sure what values to set in the PCM...
    not sure what you mean as the wider lobe separation that is ground into the 392 cam will help a heavy truck and
    as with any engine you determine where you want the intake centerline
    May 2018
    Germany
    586
    My problem is, I cant find the ICL and LSA of the stock 53022314ad truck cam 5.7.
    Even the 6.4 truck cam 5045517ac is unknown.
    The 6.4 non MDS cam ( Car) Ive got now seems to have 286/288 Dur, 46 Overlap, 121 LSA 108 ICL
    Maybe its more simple and I have to go with the car cam data in my tune ? but where is the icl to set ?
    Jan 2022
    909
    the distance from the centerline of either lobe to tdc for that cylinder is not ground into a cam
    and gen 3 hemi tuning only uses exhaust numbers...
    May 2018
    Germany
    586
    So, the question is…
    Where is the cam grounded…
    Should I use the gpec2 data from the srt minus 10 degrees for the ngc4 ?
    Jan 2022
    909
    did you limit the phaser?
    May 2018
    Germany
    586
    its a stock 6.4 non mds cam, so no…
    Jan 2022
    909
    then why minus 10 degree?
    May 2018
    Germany
    586
    Because when you take a 6.4 cam in a 5.7 the calibration of the gpec2 in the srt is different.
    Thats why Im asking this. Seems the NGC4 is similar by changing the cam.
    The 5.7s have 85* under light throttle, the 6.4s 93*. Its the same scheme I m thinking...
    Not onle the calibration is different, even the LSA makes a difference.
    Ive asking this a long time ago for the gpec2a swap, seems no one got the knowledge to explain this clearly
    Jan 2022
    909
    Because when you take (put?) a 6.4 cam in a 5.7 the calibration of the gpec2 in the srt is different.
    did you ever figure out icl? ive got a built 13 ram 5.7 with the srt non mds cam which is boosted, i have found best results around 120 degree exhaust for power and economy. but im wanting to figure out icl so i can fine tune things. cruising likes 120ish and wot above 4k im down to 113 degrees then 111 at 6k
