I was finally starting to dial in this 5.7 Durango with a Procharger when one of the injectors started getting buggy. I sent them into FIC and they send me new 1000cc injectors. Pretty sure I had 600cc before. They sent the new injector data so I uploaded it.
Truck runs awful. Light acceleration is fine but once you try to go any harder than that it breaks up. The wideband is indicating heavy lean. I've added to the ve tables several times now and it doesn't seem to be getting any better. I hit it once to get into PE mode and while it showed PE it was still heavy lean.
I tried running it with ANN on but it was the same if not worse.
Any ideas? What am I doing wrong. Rich while idling and lean while on the throttle
LARENZO.DURANGO57.PROCHARGER.1000CC.005.hptLORENZO.1000CC.005.hpl
