Results 1 to 14 of 14
Thread: Hellcat going lean on bank 1 as load increases.
    Jan 2020
    39
    2016 Hellcat
    HHP 411 Stroker
    HHP Cam
    4.5 Whipple
    Fore Fuel System
    ID1700
    Stock trans
    Stock TB for now
    Tuning this setup and no matter what it leans out on bank 1 as it goes into boost and will not richen up. There are no vacuum leaks, no obstructions in the fuel system, preload on the lifters is perfect, compression test is perfect and I flow tested the injectors which are perfect. The engine seems to run vastly different bank to bank, 9% all the way to 32%. As load goes up, bank 1 just gets leaner and leaner until the fuel trims are maxxed out and it can't add any more fuel. Just looking for advice on this issue.
    Hellcat Base Map.hpt
    Hellcat 2 Log.hpl
    Jan 2022
    904
    rut ro wasnt someone else having this exact issue recently???
    everything mechanically good but huge side to side difference
    Jan 2020
    39
    Mechanically it's perfect. I've gone over it several times.
    Oct 2016
    Poland
    1,743
    If mechanically OK next logical step would be injectors. Swap banks 4 to 4 and see it the problem migrates from side to side.
    On the other hand LTFT fights againt STFT - try to reset adaptations, you might be chasing your own tail.
    And your SD bank to bank tables are fooekd up...
    Jan 2022
    904
    whoever wrote that part does not like the flow of that blower or that manifold very much
    might be spot on just like it is - i dont know
    Oct 2016
    Poland
    1,743
    Quote Originally Posted by LilSick View Post
    Nothing justifies setting SD tables like that.
    Jan 2022
    904
    im sure his logic is that the blower discharge is not producing even airflow to both banks
    that "momentum is conserved in the absence of external forces" (newton?)
    once that thing is on boost tho, he has it thinking bank 1 is getting almost 30% more air than bank 2
    Oct 2016
    Poland
    1,743
    You create theories on demand?
    That so called "uneven discharge" is worth 2-3% not 30%...flat earth makes 5% so...
    Jan 2022
    904
    i create all sorts of stuff but i put that in quotation marks cuz i was quoting someone else , )
    Jan 2020
    39
    The SD tables are jacked because I was throwing fuel at it to see if anything would change for bank 1. It stayed lean however.
    Jan 2022
    904
    at that rpm and p ratio bank 1 should have been getting 50% more fuel than bank 2
    iirc someone else was having the same problem recently
    if it were mine i would weld in a couple bungs and install my own wide bands
    Does this car have CATs?
    2006 Chrysler 300C SRT-8
    Stock headers and cats
    Mopar CAI
    Innovate dual WBO2 sensor kit
    Custom tuning by me via HPT
    Apr 2015
    19
    Did you ever solve this?
    Oct 2019
    ATL
    57
    If anyone is still following this post.... I had a similar problem to this but it was not with a Hellcat, it was with my Supercharged RT.....
    The problem was the 02 sensors. I replaced my upstream O2 sensors with NTK O2 sensors.... the computer didn't like the NTK O2's.
    I installed MOPAR 02 sensors and the problem disappeared.
    I know Hellcats have wideband 02s and RTs have narrowband, but it is worth a shot.
