Results 1 to 7 of 7
Thread: Inconsistent Timing cut on 1-2 shift - Gen 3 Coyote/10R80
    Tuner barkingspud's Avatar
    Mar 2006
    NW Burbs of Chiraq
    119
    I thought I had this issue taken care of but apparently not. First log (3rd run 9.38.hpl) was as close to a perfect pass as you can get for the car. No issues and backed that pass up with a carbon copy. My 5th run, not so much as you'll see in the log (5th run 9.64.hpl) there is a timing cut "event" that lasts for right about .8/sec killing the run. I changed NOTHING. Any ideas/clues?
    3rd run 9.38.hpl
    5th run 9.64.hpl
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    maybe hitting engine or transmission limiter
    Turbocharged COYOTE
    PM for E tune / Remote Tuning
    [email protected]
    Mar 2006
    NW Burbs of Chiraq
    119
    Quote Originally Posted by small tuner View Post
    What doesn't make sense is the fact that nothing changed from one run to the next. I've got all the source PIDs logged. :frustrated:
    Oct 2016
    Poland
    1,743
    Quote Originally Posted by barkingspud View Post
    You are hitting cyl press limit - address that.
    Also you need to work on your SD/torque models. MAP reports 1,65 and load reports 1,75 - should be the other way around.
    Bank to bank trims are bit apart, log Rail pressure probably low and one side gets less.
    Mar 2006
    NW Burbs of Chiraq
    119
    You are hitting cyl press limit - address that. - I am actually using the Cylinder Pressure Limit table for WOT timing. So, working as intended
    Also you need to work on your SD/torque models. MAP reports 1,65 and load reports 1,75 - should be the other way around. - Understand. I actually have an updated tune with a completely new SD/torque model but it hasn't fixed the timing cut issue.
    Bank to bank trims are bit apart, log Rail pressure probably low and one side gets less. - I see that and addressing it.
    Oct 2016
    Poland
    1,743
    Using cyl pressure as a CAP is not a good idea as this is a limiter designed to cut hard. Recovery from it is hard and slow.
    Use a proper BRD/MBT method to achieve the best result.
    Feb 2016
    482
    2nd gear clutch slipping
