Results 1 to 11 of 11
Thread: How do you make idle chop harder than Ric Flair?
    Aug 2021
    837
    What tables do you need to play around with to make idle chop hard and fast.. or just hard?
    Ls7 E38.
    From what ive read and seen, most people deal with the over/under idle adaptive tables
    Spark> Idle Adaptive > over/under tables
    Aug 2021
    837
    I've been reading up on that too. Just didn't see any type of process for it. Change one and not the other or change both? No one really comes back to the thread(s) to say," that did it!" lol
    Tuning Addict
    Jan 2015
    6,802
    There are a few different ways but they'll all start around the same basic procedures and then build up to the big one.
    First Way is your basic - shift adaptive idle timing all the way to the left so it's yanking and adding timing even with 0 error and have 5ish degrees be the lowest amount. You can set this up to only be active in park or neutral and is probably your best route if you just want a little more.
    Second Way is an extension of that - it combines throttle into the mix - increase your adaptive airflow under the idle rpm tab until your throttle is opening and closing rapidly - this will deteriorate your tb over time
    Third Way - set it up to run in open loop at idle speed via PE settings and then command a PE level of something like 16 or 17 afr - you can loose take off and idle control with this, but it will literally make the car dance side to side when combined with the others. Beware - may wind up puking
    After all of that, you may want the more natural cam lope as it's better for the car and you
    ~Greg Huggins~
    Aug 2021
    837
    For the natural cam lope; do you just leave the stock settings?
    Tuning Addict
    Jan 2015
    6,802
    Usually shift adaptives to the right 1 column, so in park and neutral you have two empty cells before any corrections start. You might also want to put something like 3 or 4 in the first cell where timing is starting - not anything in the first 2 - so it will still have a little control.
    Yeah, I can't be in one of the PE fake lope tuned cars - makes me sick to my stomach - it will make it dance though even squatting the suspension side to side.
    ~Greg Huggins~
    Aug 2021
    837
    Thats too funny man! I don't need all that! I'm just going to let it do a little thumpin to suit the car.
    Aug 2021
    837
    Looking at going the first route but a little confused. Do I adjust over and under tables or just the over?
    Jan 2015
    565
    Aug 2021
    837
    Thanks! I'll have a play with it.
    Aug 2021
    837
    Thanks for the tips guys!
    For anyone else who is wanting to make idle chop, you do change both under and over tables. example: If you changed the overspeed table to -5, you change the underspeed table to 5 and it works out nicely.
