Results 1 to 12 of 12
Thread: Open loop eq error log problems
    May 2018
    Germany
    586
    A new question...
    I want log the open loop eq error via wideband and set the power enrichement table.
    Problem :
    too much data and no filter that seperates the open loop from closed loop.
    I log pressure ratio vs rpm with eq error (maths), but get data from deceleration and other conditions.
    The filter commanded Y <0,99 doesnt help at all, even map or throttle.
    What filter did you use for road logging or did you use the max negative logged values ?
    Nov 2019
    227
    I filter OL by only using the data when FA enrichment is > 0 and when the relative accelerator pedal is > 1.0V.
    Now you can use the EQ Commanded < 1.0 to define OL but this parameter has a much slower refresh rate than the FA enrichment.
    Relative accelerator pedal > 1.0V is to try and eliminate decel transients when you lift off the pedal
    May 2018
    Germany
    586
    Hey, thanks.
    So simple that my face turns to red…
    Fa enrichment should work.
    Whats the power enrichment, this value shows 0 all the time ?
    can someone post what these filters look like and how to implement them for those trying to figure this out as well?
    Nov 2019
    227
    Quote Originally Posted by JR92RS View Post
    Here the example of my OL error filter:
    [6065] is the EQ commanded channel ID and [3203.10] is the relative accelerator pedal voltage channel ID in my particular case.
    Now don't just use these ID's. Find them for your particular vehicle platform by clicking on the "New Variable" button.
    Note: you will need to have these parameters in your channel list and log for them to work in the filter.
    May 2018
    Germany
    586
    Thanks.
    I have played around with it and it works.
    To get more data in Ol, I ll set the pedal to 1,5V. treshold.
    My Afr is at 10.5-11,5 at this time - a little low, I think 12,2 is a goos and safe number.
    Jan 2022
    903
    1.5v?
    i want my afr to be above 13 with that little throttle
    12.2 is safe for 100% load
    May 2018
    Germany
    586
    When FA Enrichment is used as filter, it will also collect data from cold start.
    With EQ Commanded it collects only the warm engine data.
    But no matter what, I got always data from deceleration, even when I set 50091.156>30 - accel ped bigger then 30%
    Should I turn off the fuel cut off ?
    Real hard with Dodge….
    May 2018
    Germany
    586
    even then?.
    Zhe only way seems to set the cell hits higher then 30…
    Quote Originally Posted by HaasExp View Post
    that you so much, that shed's some light on this
    Nov 2019
    227
    Quote Originally Posted by f.creek-ranch View Post
    You can add additional filters such as & ECT>80C or something like that so it only grabs the data once warm.
    Strange that you are still getting decel data when you have filtered out the pedal voltage. In addition, the FA enrich should very quickly decay to 0 on decel so it should filter out that data.
    May 2018
    Germany
    586
    In HP some strange things will happens to me…
    Injector data gets upside down in scanner and shows data in opposite, but will work when insert in editor….
    change the power enrichement tables to flat 12 afr will give me a stoich mass and broke a piston on sc….
    These shit always happens on Dodge tuning…
    I will set the etc filter…see what happens ��
    thanks.
    Btw, engine runs on 185 deg. - hope this is not the problem.
