Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: 6L80e Circle D converter TCC Slip
    Aug 2021
    513
    Quote Originally Posted by Tre-Cool View Post
    while i dont have a solution for you. i can tell you that the whole tcc not locking up completely is something in the tune that can be turned on/off. However I still believe it's something that has not been exposed in neither HPT or Efilive.
    I recently had a car in for tuning that only had a 2500rpm stall. The convertor was constantly showing up to 50rpm of slip at light load. So i compared it to a tune i had done before that i knew had no issues with lock up (same os, but different factory transmission calibrations). So i used the other file as the baseline then copied all the exposed parameters from the original tune, then flashed.
    Instantly stayed locked & showing negative rpm slip.
    Same pressure, offsets, speeds.
    Reminds me of this post: https://forum.hptuners.com/showthrea...l=1#post487435
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Jan 2004
    Perth - Western Australia
    276
    Yep. that was OS 24256025.
    This time it was OS 24256125, commonly used in the PPV over in the states & our 2011 series 2 Commodores. This particular customer was using it in a conversion for a Nissan Patrol.
    I'll have it back tomorrow & will flash in both tunes to read out the raw bin data and do a manual comparison at a binary level. I suspect it'll be in the calibration area because copying the system segment made no difference & in the end i just copied the Calibration & diagnostics segments over & it fixed it.
    I found the output shaft speed limit doing a similar thing.
    Ha, i forgot all about that thread & that particular parameter hpt added in. Been so long i forgot all about it.
