I have been on struggle street trying to get V input from a GM 3bar to show PSI in VCM.
I can see the correct voltage but I can't get the transform right.
The reason for the external is e40 problems. I am using a 3bar map on an ECU that does not understand it so my map the ECU sees is just a reference vs a real number.
I would like to log the actual pressure during a pass in PSI. I don't want to overwrite the map, I want to add a new channel.
Tried adding it and doing a transform of (v/8.82)+ -14.7 and it does not work. Screenshot attached.
Any help would be great.
