Originally Posted by
blindsquirrel
That's all wrong.
Is it really a MAP sensor with the specs of 200/10.33, or is it something else and those settings never got changed from the default?
MAF Fail High is 16,500 and P0101-103 are No Error.
You have an Injector Flow Rate table configured for a returnless/nonreferenced fuel system (sloped), but an Offset vs Volts vs VAC table configured for a return/referenced system (flat). You don't mention what type fuel system is being used, it can't be both at the same time, so one or the other of those is wrong.
With the Open Loop - EQ Ratio table all 1.00's, I'd expect it to run bad when cold. That's the equivalent of wiring the choke fully open on a carb. No cold enrichment.
