I have the following:
'86 Silverado C10
5.3L V8 (Comp 224 cam, Comp 7.400 p-rods, Comp 918 springs, UDP)
4L60E (Transgo SK-4L60E shift kit, PTC3000 converter)
4.10 rear w/ GM POSI <--- I LOVE THAT THING!
After the first trans (stock) went belly-up after 2500 miles (no forward gears & spun bearings & bad pump), I bought a rebuilt unit (cheap). Since then, the rebuilt unit has cost me $400 b/c the 3/4 clutches went South (new clutches & shift kit were cheap, labor's a diff story), and now it's not shifting @ WOT. At one point, this made me assume that there was another problem with the transmission, so I drove it lightly. Driving it with "light throttle" gives a different feel. The trans will shift through the gears pretty descent, but it's not perfect. With this happening, I started wondering if my trans settings need revamping (line pressures, shift pressures, shift speeds, etc). I drove around for a short while trying to get a couple WOT runs, as well as light throttle runs.
I'm wondering if one (or more) of "the pros" can take a look at my tune & logs, and provide suggestions (for better direction) on what I need to pay more attention to. I'm trying to learn all I can, but don't have too much time to play... work & family with young babies. Any help would be appreciated. Thanks!
-Ron
P.S. I used to get the P0740 - TCC Solenoid Circuit code prior to these tune mods. I don't get 'em anymore. I've driven the truck "lightly" more than I have when logging. I've checked the DTCs, and have found no pending codes. I hope the converter is fine, but who knows. Thanks for reading!
