Hi
I have been chasing a problem on my Magnum for a long time and I cant pin point the problem,
car goes in Limp at part throttle when going in low boost cruising on the high way mainly on third to 5th gear ,
There is no code, just the lighting bolt in the dash, had to stop,, put in park, turn off key, open door and restart
and car will drive fine until I go part throttle again but only after a long drive on the highway.
It will do the same at the first burnout at the track on the first pass of the day only, then I am good for the day at the track doing multiple pass.
on my way back home, after 15 minutes drive, It will go in limp again at part throttle and light boost.
I can do hours of driving without problem If I stay out of boost.
Have Change the Throttle body with no change.
I am sure it is tune related.
Anyone have a clue where to look in the tune ?
this tune work very well at the track and on the street at the exception of this problem
do not have any log when the problem occur since it happend mainly on the street
magnum read 08102022 3 bar sensor new injector setting ve done.hpt
2006 magnum SRT8
405 forge motor
Stock MMX 85 throttle body
Vortech V7 on cog belt
20 PSI of boost
about 1000hp
