Results 1 to 10 of 10
Thread: ls swap timing
    ls swap timing
    so when running everything looks good but after a while of being on idle the timing goes crazy up and down. it goes from 8 to 30 and the truck sounds cammed because of it i think. how can i fix this or is it normal Attachment 133322 this a log of it
    Mar 2022
    Indiana
    2,945
    Add cylinder airmass channel to the log. Y-axis of spark tables is that.
    Mar 2022
    Indiana
    2,945
    TPS shows 4% instead of 0% at idle. Also, idle is too low. Is this engine modified? What did it come out of?
    its a 2005 5.3 4l60e with longtube, intake, 340lph pump, and straight pipe true dualls
    Mar 2022
    Indiana
    2,945
    Cable or wire throttle body?
    Post tune?
    Nov 2017
    Indiana
    329
    Quote Originally Posted by Jacog View Post
    Thats your adaptive idle kicking in. you can adjust those settings to get the effect you want. i assume youre running a P59 DWB?
    Post tune?
    its dbw and this the current tunetuned 1.hpt
    its tyhe stock pcm of the 2005 silverado and its dbw
    Nov 2017
    Indiana
    329
    Try multiplying your Overspeed values in the spark tab by by .5 and keep underspeed around factory setting for now. In your adaptive idle settings, try changes proportional idle to 50 instead of 25, integral to 10 or 15 and see if those changes help
