Hey just curious if anyone has any experience with the GM connect and cruise LS3 package. I'm running a ECM and a TCM from GM performance came with the complete package. Im using the Dakota Digital RTX gauges. I have the BIM-01-2 OBDII Interface that plugs into the OBDII port and receives all gauge information from the computer. I have used several of these on earlier big computer RED/BLUE & GREEN/BLUE vehicles with success. Excuse my lack of terminology when it comes to the computers and LS engines. But the newer LS3 Small baby computer Usually does not need a transmission control module because the TCM is inside the 6-8-10 speed automatics. But since I did not want to cut the trans tunnel I opted for the 4l65E and the separate Transmission control module. Everything is amazing. Everything works perfectly.
Except the PRND321 Indicator on the gauges. Just stays in N. My BIM is set to on in the gear position area. It shows up on the gauges.
In the HP tuners scanner I see all engine information like I normally would. But I can not add actual gear position in my tables like I normally can. Normally I can drive the vehicle and watch it shift from 1st, 2nd, 3rd, 4TH tcc downshift etc. But on this connect and cruise I can not access that information. I will try again one more time.
The gm connect and cruise package came with everything including the 4l65E transmission control module that piggy backs onto the ECM. It came with its own transmission tuning software. I used this software to set my gear ratio, tire size, and to check MPH accuracy. This software shows my Gear position when driving and mph. The only gear position I never see is P. I believe due to Park being a mechanical lock while the transmission stays in neutral.
So HP tuners no gear position coming from ECM.
Gm transmission software showing gear position! But not communication with the ECM and not sending information to the gauges.
I have the universal GSS-3000 Gear shift sensor kit STILL in the BOX. and I do not want to use it. I would like to figure out how to get that information from the TCM to communicate with the ECM so it then can be displayed on my gauges without the extra luggage.
Thank you anyone that chimes in with some information. I found this forum very helpful when I could not figure out why the vehicle would not shift and why the speedo was not working. I never would have tried to program the ECM for a manual transmission while I was running an automatic transmission if it was not for the forum. I wasted 8 hours checking all wiring and VSS when the whole time it was a small program change. Hoping to find some quality information on this matter as well. Thanks.
