Results 1 to 9 of 9
Thread: Error Opening Scanner
    May 2006
    Upstate NY
    207
    Exclamation Error Opening Scanner
    Ok, i want to get this problem fixed. It's getting really annoying. If I don't close out all of the open windows in the scanner, then next time I open it up, I get the error in the picture. I can hit continue and everything is ok. I can have every window open when I close the scanner and then open it back up by double clicking on a log and it loads fine with no error. I've went back and forth with support a while ago and we couldn't fix it. I'm currnetly on a new laptop with a new hard drive and a fresh XP Pro install and it still does it. Has anyone else run into this problem and found a cure?
    Tim
    GM World Class Technician
    ASE Master Auto Technician
    L1 Certification
    2001 Silverado 6.0L Swap
    Sep 2002
    Chicago, IL
    6,395
    What version of VCM Suite are you using?
    Set it up so it crashes, then e-mail me your vcm scanner.cfg file and the config file you are using for the scanner. vcm scanner.cfg is located in c:\program files\hp tuners\vcm suite 2.
    We got this guy Not Sure, ...
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I have had the same error at times, don't think I did anything different to cause the error message. I just ignored the error, and the scanner worked fine.
    Russ Kemp
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    russ & bullygoat would you both mind posting a vcmsuite info log minus your application key & serial number please...I'd like to see what versino of net 1.1 your running.
    Bill
    May 2006
    Upstate NY
    207
    Here's mine.
    Tim
    L1 Certification
    HP Tuners Support
    (foff667)
    28,266
    yeah I think I found one of the problems...try installing sp1 which can be found here http://www.microsoft.com/downloads/d...displaylang=en
    and let us know how it works out...hopefully that'll cure all your ills though.
    ps check your version net 1.1 russ...if it ends in .573 a bunch of us have had issues with that version...just upgrade to sp1 & all of our issues when away.
    Sep 2002
    Chicago, IL
    6,395
    Ya, sp1 should fix the issue. There is nothing wrong with the configs I received via e-mail.
    May 2006
    Upstate NY
    207
    Yup, sp1 fixed mine.
    Tim
    L1 Certification
    HP Tuners Support
    (foff667)
    28,266
    Great, Glad to hear it.
